Jay Liedman
This is going to look like an extremely dumb question to anyone familiar with LP/Propane systems, but I have never used or worked on a propane system before, and neither has my local mechanic.
We are thinking there is something wrong with the regulator or carb because it does not shut off the propane flow when the tractor is turned off. One has to turn off the valves on the fuel tank itself to stop the flow. The mechanic is thinking something in the regulator or carb should stop the gas flow when the switch is turned off. This is a Ensign (model R) brand regulator and carb.
Are we correct in thinking the regulator or carb is not working right? If so, what might be the problem? Are there any shops in the upper Midwest that fix these old Ensign regulators?
