Re: Opinion time: Ether or not?
jr1983
With a block heater a pan heater and good battery's if its like
any mm I've ever been around you'll still either them
morning jr. next time your doing a cold start try brake clean instead of either, it's not quite as explosive as either, just use it like either small squirts it works quite well. john
Ether can crack piston rings if a person isn't careful.
We have engine block heaters in two 585 diesels and a 336 diesel. Plug them in overnight and all start on their own very easy in the morning.
(quoted from post at 06:52:01 08/26/17) Ether can crack piston rings if a person isn't careful.
another trick to cold winter starts is a 100 watt battery blanket wraped around your battery, at 100w they draw very little power and keep your battery toasty warm. a battery sitting at -20 degrees only has 50% power output.
