Moline Filters
molinegb
After pondering project for some time I have decided to maket MM filters.
Getting tired of hearing NLA when most Moline filters are available. I have a supplier for
most as well as know of collections of obsolete filters.All filter will be built to spec or
NOS. I have collected and researched MM's for close to 30 years, I am going to compile a
list of filters. Have sold filters to many here and abroad. Just need input on whether
there is enough interest. No intent to step on anyone's toes. I have had numerous requests
so I had to progress.
The early M5 s have filter on lift cover. Its the short can on rite with bolt head. Late units have filter in can with big steel lines mounted on left side mounted vertically.
Like Shaun stated early M5s were like the 5 Stars with the steel canister on
the lift, kind of in front of the hyd levers. I believe that filter is
available yet as a fuel / oil filter. Later ones were on the left side on an up
and down canister.
thank you alan I will check on that as soon as I get back out to the tractor this week, my manuals I ordered on here haven't arrived yet so look on the tractor when I get there.
Small demand I am sure, but oil filters
for UB Special gas/propane are nearly impossible to obtain. I wish you well in your endeavor
molinegb is correct. You have the type E hydraulic system on your M5. They dont
have the filter system like Shaun and I mentioned.
- First filter that comes to mind. A filter like the T!5M ( I think is the baldwin number) for the R&Z's...
-Second would be a filter that actually fits in the canister of the later Tele-Flo tractors ( Jet 3, U302, M670)
Filters in both sock and paper type available for R/Z U/G. Special filters for UB and U
also as well as the U diesel and U diesel Special. These filters are getting pricey just
like everything else!Will be working on list and pricing after summer. Busy now.
