GVI paint advice needed
jnf
I will be painting a GVI with bronze metallic and prairie gold III or power yellow. Using acrylic enamel that is thinned one part thinner to eight parts paint. Can anyone recommend what quantities of each paint to order?
jetstar(dot)Minneapolis-Moline(dot)com has paint code chart for letter and number models.
GVI should be Prairie Gold III, not power yellow
You may not use all of it but you'll be more comfortable with a gallon of each. Unless it is a personal preference, no power yellow on a GVI.
Thanks to each of you. I will use prairie gold III which I understood to be the same as power yellow back in the day, not the same as energy yellow as used on a G706. Thanks again.
Bronze metallic is tricky to paint with, (any metallic) to heavy of a coat ,or to slow of a pass and the metallic will sag or run. it's just a little difficult. Good luck
