MM BF (sediment bowl gasket/screen)
grayrider
Forgive me for probably asking a simple easy to find an answer question., I'm a Ford tractor guy that gets parts any and everywhere easily whether local or ordering online. This MM BF that I'm doing surgery on is starting to be a challenge, I think the Avery R is the same tractor and not having much success trying to find bits and pieces online, I need a sediment bowl gasket and screen for it now, does anybody know if TSC has anything that will work
There were 2 basic sizes of sediment bowls used so there are 2 different size gaskets. Check with about any implement dealer or a good auto parts store or farm supply store like TSC. You have e-mail? I can give you some pointers on your water pump too. My e-mail should be open. J.
I do not know that tractor as such but in all the dealings with all the tractor I have messed with over the years 99% of them used the same gasket and I have only found 2 different screens so yes TSC or even O'Reilly's auto parts can get you the parts. O'Reilly's gasket number is 398 fuel strainer gasket
