GBD actual wheel width 23.1-26?
schramm
I'm trying to figure out what the actual wheel width is on a 1959 Minneapolis Moline GBD with 23.1-26 rear tires. I'm trying to determine if a used tire from a 1965 Ford 5000 diesel with 18.4-26 rears would be able to fit on the GBD wheel? Thanks for your help.
I have a Case LAI that I put an 18.4 on one side to replace the 23.1x26. if you need measurements I could get them.
Rim size should be 18 inches. An 18.4 tire is meant for a 15 or 16 inch rim. It may fit, but look odd. Ben
