MM U radiator cap
kip78
I just purchased a 1952 model U tractor and
the cap is all loose on the radiator. Is
this a pressurized system or not?
lots can be changed in 64(65) years.
Does the cap have the tabs on the inside or outside of the radiator neck?
If they are inside, (like the gas cap) I think its a non-pressurized system.
IF the tabs go on the outside of the filler neck, I think its pressurized.
I am also thinking that even a non-pressurized cap should have a gasket to make it fit tightly. We had a loose cap(non-pressurized) on the Farmall Cub and it steamed the new paint off the hood.
If pressurized there is small notch in hood around rad cap. Not until 1953. 1953 hood won't
fit 52.
