Ensign Propane Parts
Are there any Ensign propane parts (or aftermarket) parts available anymore? I have a GB propane that is acting up. The fuel system seems to run lean. The engine cuts out backfires when cold. The tractor has an Ensign Model R Regulator. After the tractor warms up, it is not so bad but not 100%.
Contact Dean Zingre at 8one5 four99 8708. I believe he works in the LP industry and has some parts. He is in ILL.
I have a regulator off of a 604 that had a complete rebuild kit put in it 2 years ago, but never ran. I switched and put an impco on it. I would sell the regulator I have if interested.
I replaced the ensign regulator and carburetor on my g with a new regulator which I had to make a new mounting bracket and I installed a new carburetor as well. Made a world of difference. The ensign system didnt work very well, to complicated. I could get you the parts that I used if you would like. Thanks
