I'm in the process of reviving a GVI, originally LP, but now on gas.First question, where would I find a new lower rad hose? Haven't had any luck with my local suppliers, but I don't mind mail ordering for parts. Next questions are about the hydraulics- this tractor has the early Webster pump, and two Char-Lynn valves. The setup looks correct, with the right pressure control valve. Does this system require the original type "locked circuit cylinders", or can regular cylinders be used? Can one cylinder float? The factory specified fluid is MM 10P 706. What is a good modern replacement for this? Temperatures in our area run from about 0F to 85F.
I like my Prairie Gold, and enjoy reading this forum. Help is always appreciated. Thanks, unc
