1940 RTN brake pedal spring question
avery2550
New User
I just finished up with the brakes, axles seals and housings back on. I'm trying to figure out the correct springs and placement between the park lock dog and the bent piece of round stock that goes under the pedals with the small hole in it. Parts book says there are two springs. Maybe somebody has a photo of the set up on a tractor?
Thanks
Matt
One spring goes from the hole in the small bent rod you mentioned, directly up to and around the shaft that the dog rides on. The other goes from hole in brake pedal to the hole in the side of the dog I believe. I'm on the road right now. I can snap a pic when I get home and send it to you.
Ok good! I did notice that other hole in the one pedal. A pic would still be better yet. If you are able to get rough spring dimensions I would really appreciate it too.
Thanks!
Matt
