445 Diesel Generator
molinegb
Original generator was a add on. Used one off a m5. It sits about 1/2 inch forward and belt is not lined up. Not alot of room as back will hit diesel pump. Measured several and all same length. Have several brackets but still won't fit. Maybe different pulley? Does anyone have a picture of original setup?
I might have a picture in a supplement manual for a diesel 445. Will have to take a look.
Found a picture. Crossed bracket and generator numbers. They are same as Jetstar Not sure what is going on.
Checked generator again. It is sitting about a 3/4 a belt width ahead of other two pulleys.
Tried original generator on and it lines up perfect with same mount. Measured waterpump pulley to block and it is same as on another 206 combine motor. Generator that was on it was a Ford and it fits way better than Delco. Could it be original? I could shim behind waterpump pulley to make it look better. Waterpump pulley measures 3 inches from block. Crankshaft pulley is 3 1/8 and generator 3 1/4. No room to move generator back as it will hit injector or return block on injection pump.
Problem resolved. Someone had pressed waterpump pulley hub on too far. Used puller to make shaft flush with hub. Lined right up.
