minneapolis moline zas
so my zas is not running right clean the carb many time everything is clean no blockage in there but still not running right always shoot gas out the carb
now it timed it looks good everything look right the rotor lines up when the piston is on compression now i have 2 marking on the cam which on should i be going by any advice would help thank you
What do you have for markings on the flywheel? If I remember correctly you were supposed to put a mark 2 1/4" from TDC. There is a cast "pointer" on the opening by the flywheel to use for a timing light.
