445 Tachometer Drive
molinegb
Working on 445 diesel with cast side cover. Tach drive is mounted right in casting not like the later ones that have 4 bolts to remove. Books don't show breakdown. Tach shaft and gear is gone completely. Any know how to remove top piece. Doesn't appear to have threads.
Managed to get drive assembly out. It is pressed in. Mine was worse than others as the gear and shaft had broken off. The end was burred. Had a tough time getting it out. It is same side cover as on my Motrac diesel.
