MM Z model gasket question?
Anyone with Moline Z Ztu ZTn Zta etc. Know
of any reproduction gasket on the " Oil
Grove " cover plate? Its the little small
plate right below the valve cover dead
center.? Its has a gasket which has 3 little
holes in it.😒which think looks to be made
of rubber/paper matrial? Is there a repro
for this ..... anywhere or can you just make
a regular gasket without the holes and just
stick it on? Or does it need them?part
number is #RE158A.
If you go to Napa and order the FEL pro gasket set it will come with that one, and every other gasket. I believe the set is around $100. They can probably be gotten individually from Agco otherwise.
Those holes are needed. I believe they are the oil gallery between the blocks for the rocker arm oilers. I think there were 3 total in the middle. I think the original gasket was 1/16" thick made of cork. Rubberized cork will hold together better. I may have a spare one here.
Hello alan. I sent email not very sure they are coming through? Let me.know if you get any.... deff interested in gasket if have one sir.
Alan, sent another email not sure they are coming through or not.. but yes i will take one of the gaskets,get back with me let me know sir....thx again for the help.
Wes,
The easiest way is to make your own. I buy sheet gasket material from NAPA and cut/punch out my gasket. The only gasket I can't make is a head gasket.
