UTS axle seal source please
sms
Trying to stop leaks on my 1941 UTS. I think I have the inner felts (UT309) for the rear axles but need outer seals/felt (UT458A) and also seals/felt for brake shafts (UT357). And are these the right part numbers? Thanks
Have you tried your AGCO dealer? Some of that stuff is still available. Or they can sometimes do a search and find a dealer with some NOS parts on hand. They should also be able to tell you if your part numbers are correct.
Just found in my book where I wrote down;
UT459A=CR 35012
UT459 =CR 35082
Belt Pulley is UT 309
Brake Shaft UT 357
Best I can tell. If anyone has anything for them.
