1940 RTN valve spring installed height spec
avery2550
New User
I'm finishing up assembling the engine on my
1940 RTN with new valves and springs. The
manuals I have don't list a valve spring
installed height. Was hoping somebody could
help me out if they had a more detailed
manual with the spring installed height
specification so I can get them shimmed
right if needed.
Thanks
Matt
Charlie Biler at external_link.com is the only person I know of that may have that information. I think he had those springs reproduced.
As far as i know, most people just put the valve springs in and they work fine as long as they are not 'tired' or weak. Its not like its a 6,000 rpm small block. I always did and they always worked.
A friend was able to find the specification of 1 9/16" at their machine shop today. So I checked them and have them assembled. I shimmed one exhaust .030" was it. Exhaust valves are the ones that will give trouble if not enough closed spring pressure when idling or a no load situation causing a miss.
Thanks for the reply.
Valve springs 1 19/32 when fully expanded. Valve springs compressed to 1 9/16 has 27 1/2 pounds pressure. Compressed to 1 13/64 requires 56 lbs pressure. Should help some.
