Have a new to me U302 and am in the process of going through everything on it. I have a few questions I'd like some advice on, feel free to comment on anything, I appreciate it!
1. Best way to clean up some sludge in the engine - Diesel or kerosene and drain oil?
2. Clutch adjustment - Where is the right spot to measure the travel of the clutch pedal?
3. Carb adjustments - the process and adjustments for a marvel schebler carb? Looks like the manual i got might no be for same one and want to be sure.
4. Blow by? Puffs a bit when oil fill cap is off and a little from the breather which i didn't see when i was looking at it. I haven't had an opportunity to do compression tests yet, but plugs look good and it doesn't smoke. Just curious on that
Thanks for any help!
