MM GB Ensign Propane Fuel Filter Number
Does anybody know which propane fuel filter goes in a 1957 Minneapolis Moline GB? My MM starts and runs really nice and then starts cutting out and eventually dies. The problem is not electrical. I figure the filter may be dirty. I just picked up the tractor and who knows how long that filter has been on the tractor. The filter is located in an Ensign filter housing.
Thanks.
Baldwin Filters shows a PF-224 with Qualifiers (LPG) (10P-2554) for the M670 MM tractor. I believe there was only one style of Ensign filter back in those days. My '65 M670 has the complete Ensign fuel system on it.
Bryce
praireplow07,I stock the filter you are asking for. I also stock the valves and other misc. l.p. parts for the Molines. Are you sure you are getting a good flow of fuel?? The reason I ask, I had a situation where the spring in the valves, (liq + vapor) was weak and letting the valve go closed. I can be reached at 815/499/8708 if you have questions. I do work odd hrs. , but you can leave a voice message if I don't answer. Before 2 p.m. is usually good to reach me. I work nights, so I hit the sack early aft. --Dean--
