majorlucas
I have 2 telo-flow hydraulics that need work. One valve is keeps lifting when it is centered and on another tractor the 2nd remote doesn't work unless the 1st remote is being used......
My question is: Is this an on-the-tractor fix? Where I can synchronize the spools and replace the o-rings? Or do I need to lift it off?
I am guess the one only needs o-rings, so I was thinking about pulling the valve body and replacing any o-ring I find....
Thanks!
Thanks!
