UDLX in Alberta, Canada in 2007
The discussions a pictures about the UDLX tractors the last while has been fascinating and entertaining. Thank you for all the cool stories 1206SWMO!
I've only seen one in person, and that was in 2007 at the show at Pioneer Acres in Irricana, Alberta, Canada. Sadly, I didn't think of writing down the serial number. Here's the pictures I took.
Thanks for the pics...I recently found out about this one.....I think that it may have changed
hands since 2007....The new owner has another one for which I have the serial number for but
I don't know about this one because I'm not sure of its history from the 1980's....I'd say its
50-50 if I have it..
The bad thing about getting a UDLX serial number is that you have to get under the cab and
sit on the ground....You will probably need a flashlight to see it unless the sun is real bright
and you will need good vision which mine isn't..Vanderbrink Auction sold a UDLX at Grenora,N Dakota
in 2011 and they only gave the engine serial number for it..
Good to know, I haven't been down to their show since then, so wasn't sure if it was still around even. If I do come across it, I'll be sure to check the serial number. I don't mind getting a little dirty, it's part of the hobby! :wink:
