Lyndon - AB
I have a bit of a theory question for you guys. I have a frankenstein Massey that's a cobble together job of a Massey 95 and 97. I thought it was just a 95 rearend with the 504 out of 97 in it. Not so much. Tried pulling with it, but it won't pull the hat off your head. Turns out it has the Bosch pump off of a 95 or Super 95 on it, instead of the Roosa Master that should be on there.
So, here comes the theory part. Is it possible to crank the Bosch pump up enough to get the 504 pulling good, or should I look for a Roosa Master from a 97/G705?
