PTO safety guard
I have seen a safety guard designed to cover the PTO on a 1946 ZTN. But did MM make a safety guard when a mechanical lift was installed? The PTO extends out the back of the lift. If so, does someone have a picture?
Don't know what went wrong but lost my message in first post. These are on a 47 U. I would think that a Z would be same.
Was at a MM auction in ND and there was a pile of pto lift setups. Think they went scrap. Not a good setup. Most were taken off.
A Z guard is different. The platform doesn't go back far enough to bolt on like the guard you pictured. I have a Z with the lift on it and a guard hanging in the shed. ( don't use the PTO). But my camera isn't working right now. It is basically the same guard, but the angle iron at the bottom is extended and curves upward to extend over the shaft.
MMDEL
Why do you say not a good set up. It was as good as any other manufacture at the time with platform behind the rear axle
MMDEL.
