445 radiators
molinegb
Do anyone have a parts book for 445 diesel? My radiator is not very good. Was frozen at one time. Wondering if 445 gas and diesel used same rad.
If you can still re-use your top tank, I would suggest having a radiator shop re-core the radiator you have.
My 445 parts book R-1157C
10A7304 Core--Radiator with pressure cap
Used on tractors equipped to operate on gasoline, tractor fuel or LP gas
10A13136 Core--Radiator with pressure cap Used on Diesel tractors
Also need top tube that connects to top rad hose from block. Gas the same? May have to make one.
I had a bunch of those tubes bent up for Jetstar-445 series tractors. I think new from Agco they are around $350.
Any other models use the same rad? Don't have my books handy,snowed in. Have a couple of 5 Stars and M5 diesels. Probably bigger.
