4 Star Diff cover extra holes
matthies
Putting the diff cover back on and can't think what the two 3/8 holes are for towards the rear of the cover by the pump pressure and suction ports. There is threaded holes in the case, maybe for a seat mount for a tractor without three point? Going to put two countersunk flat screws in to plug the holes to keep dirt and moisture out and keep oil in, not a lot of clearance for regular bolt heads and parts book only lists the four 5/8 and seven 3/8 bolts for the outer holes. Will have to look at the old gasket to see if the holes are in there. thanks chris
