ut wide front help
Remove the nut holding the spindles on the narrow front, located under the spindle. Might have to use a puller to remove the spindle.Nothing else to dissemble except the hubs and bearings.
I see exactly what you're saying now tractorguy1951. take the nut off the bottom of the row crop spindles, pull them off, then slide on the arm that moves the tie rods on to the splined shaft and replace nut. wow I'm sorry I overthought the heck out of that one! I really appreciate it. I've worked on alot of Allis Chalmers WD's and CA's but this is my first Moline and it's definitely been a new learning process. Thanks again!
