4 star tierod assemblies
matthies
Does A&I or a complete assembly from another tractor work on a Type E wide front axle? Need tube and both tie rods for both sides. These are threaded on one end and notched for a bolt on the other end of tube. thanks chris
Glad to see you working on the 4 Star. It should fit on the trailer like the JD 50, but pull the hills at Mapleton much better. Still planning on giving you a lift next summer.
Wayne
Just a little here and there, started on a Jubilee Ford, was running bad, found two broken exhaust valves. Went to Walthill today and got what I needed and installed all the valve springs. It needs a little more attention. Have to do my brothers chores all week after work he has some training with CaseIH in South Dakota. So don't know if I will get in the shop or not this week, hope this weather holds out for awhile. You have to let me know what Saturday morning the crew gets together so we can chat, also let me know when Harolds stuff sells, though it won't be till after the first of the year I'm sure.
