We have a couple of minor leaks on our G1000 LP system. We are now almost empty and Winter is approaching so we decided to make work of them. The first one appears to be around the gauge. Has anyone had these gauges apart before? Looks like it is leaking around the base and will need a new gasket. Are those a standard LP gauge, or something MM specific?
The second leak is on the vapor valve. If you open it up much more than a crack it leaks out near the handle. I assume it is some sort of packing issue inside. Any ideas of how to approach this one? Can the valve be removed? Are they MM specific or something I might be able to get from an LP or High-lo supplier?
Sorry if these are rudimentary questions, have not worked with an LP tractor before this one so this is new territory.
Thanks,
Ryan
Thanks,
Ryan
