Stuck Saddle On lower 3Pt Arm
KCTractors
Location
Central Wi
The lower 3pt arms are stuck, the part that comes out to hook-up 3pt equipment (saddles) I guess that's what they are called in the parts diagram. I had them in a parts-washer for a week, I chained them to a tree with clevises on both ends. I hooked them up to a Moline 602 to try to pull them apart. No go, any ideas. I don't know the history of this tractor (445) as far when they were moved the last time.
Heat, oil, hammer, repeat and repeat. An air chisel with a punch bit could be quite effective, along with heat and lube.
