On a MM 602, 1963, where do you check the hydraulic oil level? Operators Manual says dip stick, right hand side right below seat. Mind does not have one. Can't locate or see a oil level plug in that area or any area around the seat. Thanks.
First of all, do you have the tel-o-flo system with 3 point hitch? If so and if the pipe hasnt been removed, they were on the right rear of the hydraulic reservoir, which is kind of under the seat and to the rear of the hydraulic levers. It will be a long pipe, about 10" or so. If you dont have one there you can check it by removing the rate and cycle levers under the seat (four 1/4" bolts) Oil level should be about 1" down from the top.
