Trying to find a hydraulic pump for a G550. Can't seem to find one on the web. Can anyone give me some information on where to get one or who can rebuild them. Thanks
It should be the same as an Oliver 1555 tractor as the G550 was a 1555 done over in MM colors. An AGCO dealer would be aware of this but other sources may not be. Try Maibach's in Ohio or Coryn Farm Supply in NY at 585-394-4691.
Don't waste any money on rebuilding a gear pump. Rick Stairs can fix you up with a new pump. You have a rare tractor!
I have put the pump made for the 1650 thru 1950 in 1550s. You have to replace the driven gear with one for that size pump-155741A is the part number of the gear. Should be able to find a used gear. The 1550 pump has a smaller input shaft. Other than changing the gear everything else fits.
