Moline G6 weight
fdt860
Does someone know the weight of a GVI diesel, with PTO, and those wheel weights on the back? (and the weight of each weight)
Moline operators manuel says "dry weight LP 7650. There are several sizes of those weights. Yours look to be about#350 each.
(quoted from post at 08:08:57 10/01/16) Moline operators manuel says "dry weight LP 7650. There are several sizes of those weights. Yours look to be about#350 each.
Even the inside one?
The outside wt.is 400#, Have weighed several in the past. No idea about the inner one. Is it a M M weight? It looks different to me. clint
My GVI diesel weighed 8000 lbs at the Adrian,MO pull but I know the scales were light...It has a PTO,no fluid,and no weights...It did once have some big weights on it that were very heavy..If it had a few more horses it would have won the 7500-8500 class in a weight % pull..
My GVI weighs around 8300 with no fluid in the tires. I can pull in the 8500 lbs class.
(Unsure of the the wheel weights)
What the guys say about tractor weight would be fairly close I think. Wheel weights, well I can say is the are or were the maximun weight I could lift off the ground on my own but that was 3 or 4 years ago, definately very heavy.
I have several GVIs and they had different outer weights some were much thicker than others and different diameters I have seen GVIs from 8200 to well over 12000 depending an accessory weights the largest set I have has a G cast in the center. in a world of computer managed junk the GVI was simple raw dependable power and even today they are feered in the tractor pull world. Never in the history of tractor pulling has there been so many rules made against the GVIS.
