minneapolis moline pf3-7 grain drill
Kenny S.
New User
Need a seeding chart for a minneapolis moline pf3-7 grain drill. Need to put 112 lbs of rye to the acre and can't read the settings on my drill. Can anyone help?
Chart in book says for rye HIGH GEAR , notch 14 on dial plate is 56 lb ,notch 16 is 65 lb, notch 20 is 96 lb and weights on chart end there so at that progression I'm guessing notch 25 or 30 should get you about where you want to be.
Thank you so much! Did get help from another place, and they said the same thing. Appreciate your reply.
