Larry B. 1486
I am hoping someone has some information on a Avery Model V with a Hercules 65 CI. Was told it is a 1950 model. From what I have read that Avery was bought out by M M in 1953 and the model V was just repainted with M M decals. This tractor has been sitting for around 25 years, inside a building. I pulled it out about a month ago and am going to try to get it running again. Someone replaced the distrubitor cap and put in new plugs and wires. They have it wired firing order 1 2 3 4. Should the firing order be 1 3 4 2? The plugs they put in it are Champion # HIOC. Is this the correct plug for this tractor? I had to replace the manifold and when one stud came out, antifreeze came out of the stud hole also. Would this be normal? No antifreeze in the intake or exhaust ports. Any info will be greatly appreciated.
