Hello to ALL.
Bought a UB-lp this early spring to run the whole farm generator. I have used it so far around the moving wagons hauling water
to the cows, just a all around yard dog. Never runs very long and not worked hard.
It has just burned out its second Pertronix Ignition 1142, both times tractor ran fine was shut off and when tried to restart
not a pop, never ran after that.
Tractor has one wire Alternator, changed to 12v negative ground, new coil, new wiring. Tractor has ran less than one hour on
each of the two Ignition part changes.
My question is, has anyone gone through this burning out this conversion. What do I have wrong?
Thank you for the help.
