ZTS Ready for the hayride
Just pulled the ZTS out to give the grandkids a hay ride.
The tractor is a 1940, Unsure of the cast wheels. I haven't changed it much
since I acquired it. But the paint is a brushed on mix purchased at Home Depot.
It is a little brighter than my other Moline's but it sure does pull a hay wagon easy.
Looks good. I will never say anything bad about a brush paint job, been known to do it myself. Knew an older gentleman that painted school buses with a brush when he was much younger.
On my UTS I brush painted all the cast parts and only sprayed the sheet metal. That way I could do it at my own pace, plus I didn't have to worry about lying on my back with a spray gun trying to spray the underside.
Nice. Just wondering, do the rear tires have an "S-3" on them? If so, they were the synthetic rubber tires made during WW2.
Sweet looking tractor. Mind if I ask what mixture of paint from Home Depot you used? I'm in Canada but we have Home Depot here locally and I have a U that could sure use a coat to brighten her up a little.
Here is my 1940. Notice the wheels.Must have been two different styles. They are actually left over from JT models.
Nice looking "40". There is a Z not too far from me here in Michigan a 1937 with the same wheels as my 1940. And then I have a 1938 with cast wheels which is a ZTU. I have only owned my ZTS for a year now and know very little of it's past history. But there seems to be a science of front and rear pressed steel wheels. It seems that every Moline Z I own has some unique difference in rim configuration.
Alan, You are correct there is an "S" on the tire. In fact it states "S3". Thanks for the history
. Some of these facts are very interesting to know.
You know back in the era when the Model T was made. They hand brushed the paint on then lightly sanded the finish
. Now I have never seen the early Twin Cities come off the assembly line. But I wonder how far off we are to the finished product.
My dad mentioned that to me once. My uncle (now his sons have it) had a 1939 ZTU that has one of those S-3 tires on it that has the "H" style cross pattern. It is still on the tractor. Dad always said they slipped a little more than the regular rubber tires. Maybe because they dont flex like regular rubber?
The S tires may have had the red inner tubes which were also synthetic. The synthetic tubes/tires were wartime replacements for rubber restrictions. This is where the JT cast steering wheel was used instead of the rubber ones. Of all the wartime MM tractors I have owned (over 20) 3 have cast steering wheels. 39 U , 44 Z and a 43 G.
The cross tread original tires were not synthetic as they date back before wartime.
Roger, where are you located in MI? I'm halfway between St.Johns and Ithaca. I did have some valve train parts I was told were from a MM tractor that came with a bunch of Oliver parts I bought. I'd give them to you if I can find them, if you could use them. I'd like to have an MM someday, though I only know a couple people around here that have any, so I'll probably never use the stuff. I think it was rocker arms and maybe engine valve train covers that I had.
Ross
(quoted from post at 16:03:23 08/05/16) You are going to laugh, But it is OSHA Safety Orange.
Thank you for the information about the paint you used. No I wouldn't laugh because I think your tractor looks awesome. I have my dad's MM U bought a month after I was born and its still running. But, like me it has a few aches and pains. It desperately needs a new coat of paint and an exhaust manifold and heat riser valve.
Thank you again for finding the information for me. I will see if our local Home Depot stocks that paint.
