Moline R torque
Ken M
What is the torque for the cylinder blocks to the main block? Mine is weeping just a little around the base.
I dont think there was a torque on them, just to tighten evenly. Keep in mind, when you tighten them it can change your valve lash so you might have to reset your valves.
I never saw specifications for that in MM literature. I always used the Standard torque table from my Kohler K-series manual. For the block bolts, rear appliance bolts, cam bearing caps, etc.
If your engine is leaking much there, it is probably time for new gaskets.
