Just became the proud owner of my first Moline. Bought on an estate auction. Needed new batteries and it took off on the first turn. However, it seems to have a bad radiator. I could see that solder seal had been poured in it and when I started the tractor anti freeze came out at a rapid pace I was hoping it was just a hose but it isn't. Now for my question. It appears as if the radiator needs to be disassembled leaving the bottom. Lots of 5/16 bolts, but it looks like it should lift right off. I would assume there is a gasket between core and bottom tank. I wonder if the gasket is still available or could I use a gasket sealer? Want to get it going. Got some work for it to do.
