obsolete gasket needed
Anyone know where I can find the gasket that goes between the rear axle housing and rear end on a G705? Acgo no longer has them.
There are some auto parts stores that carry gasket material. If you cant find any there
Im sure somewhere on the internet it is available. I wouldnt go to thin with it and I
would use some silicone on it as well.
I am pretty sure I have some of those gaskets. They are fairly heavy in thickness. When I finish farming this week (spraying beans) I will check.
MMDEL
Yeah I got it apart, cracked it good on the end with a sledge hammer and it started to come free, the gasket was all that was holding it, no dowl pins at all on it. Now I'm fighting with getting the outer bearing and the sleeve of the axle shaft without ruining anything . Is it safe to heat that sleeve? Any tips on that? MMDEL I'd sure appreciate it, Kelly Stamm is also checking to see if they have something but Clint isn't doing the best now so it may be a bit before she gets back to me.
Dont use silicone use "Right Stuff" gasket maker. Kinda spendy but much better than silicone. Any auto parts store will have it.
Sorry, I meant to get back to you a few days ago. I looked high and low but did not find that gasket. I sill think I have more than one. Makes me mad.
NNDEL
Thanks for looking, if I can't come up with one by the weekend I'll probably use some RTV or something . Making that gasket is not something I want to do, lol. To many holes and not enough patience.
