White 8900 Combine (Hydraulic Pump - Webster)
Jeremy L
I am looking for a new or remanufactured hydraulic pump for a White 8900 combine. I believe it is a webster pump. Agco says the pump and basically all parts other than the seal kit are discontinued. Is their anyone who may have a replacement pump or who still fixes these older pumps?
That pump looks an awful lot like the pumps on our 9700s/9720s & 8590 Masseys (all the same basically). We could not find any replacements and tried using ones from the salvage yards until they were shot, then rebuilt a couple making one from two etc. but they would only last a little while and then start leaking or blow out too. I was told they were a through away pump. We had to have 4 new ones made to replace the originals and they are not cheap. I think the first ones were about $900.00 and the last one we did last year may have been about $1400. They need to have a built in priority setup for the steering I guess. The new ones are about twice as big and we had some leak problems with them too. They will fit right in though with no new lines needed.
Did you check a pump from a Massey 750-860?
They are very similar, Cessna as well, with same flow divider setup for priority to the steering, about $650 on the internet for a new one.
