Most of you will remember me posting about my GVI MM diesel that hadn't run in 25 years..It was a battle
to get it running but in the end it ran great...I took it to the Adrian,MO tractor show on June 24-26th as they
were featuring MM's..
For years all thats pulled the 7500-8500 class at Adrian was 70,720,and 730 JD's..Its a 1st gear weight
percentage pull....This year there were (3) 70 JD's,a 730 JD,and my GVI MM..
1-The GVI MM ran out of power shortly after this picture was taken..It weighed 7800 lbs (scales were light}
and pulled 230% of its weight which was good for 2nd place....The winner was a 70 JD diesel that pulled
238%...The GVI is geared just a little too fast in 1st gear...I had a 4020 JD drawbar on it and almost picked
the front....It was sure hooked to the track..
2-I pulled my 1940 UTU in the 4500-5500 class (weighed 5205) and after 8 tractors had pulled I was in the
lead at over 300%....It jumped out of 1st gear just over half way down the track....I had the option of going
back to the starting line or taking off where I stopped...I took off where I stopped with the front 2 ft in the air
and ran out of power 75 ft on down the track...The last 2 tractors in the class got by me but not by much...
An M Farmall was 2nd and a U MM 1st.
3-My 1948 U puller taking it to the end of the track on an exhibition hook in the 4500-5500 class..I only ran
2nd gear because you have to stop before the weight box tops out..
4-The U MM that won the 4500-5500 class....Its belongs to the Bents family from Deepwater,MO..It weighs
4900..
5-On Sunday afternoon I was going to pull my 1929 21-32 Twin City in the 5500-6500 antique class but a
storm hit shortly after the pull started dumping 2.33" of much needed rain..
4900..
