Tony in SD
I bought a MM ZA. It sat outside forever and the rubber gear shift boot was gone. Big surprise........ So as you might have guessed the transmission was full of water. Drained the transmission, flushed with diesel and refilled with 80-140 synthetic Transmission oil. There is quite a bit of tranny chatter. Im looking for advice on what I should do to quite the chatter. Straight 140? Open it up to inspect/replace the gears and/or bearings? Nothing at all? I should also say it is not a work tractor anymore just an oldie that is in the progress of becoming a full time parade tractor.
Thanks in advance for any advice.
