MM G955/Oliver 1870 Valve Cover Breather
Jeremy L
Does anyone have a picture of the top of the valve cover where the breather connects to it on an MM G955/Oliver 1870? Are the tops of these valve covers different than those of the GVI/G705-708, etc.? I am assuming they are the same in the sense that the hole in the center and the brace underneath with the threads to accept the stud that holds the breather on are all the same but I would like to confirm this if possible. Any photos of a G955/1870 valve cover and breather would be appreciated.
Thanks in advance for your assistance.
To bad you didn't post this yesterday. As I still had the hood off then while I put a new mechanical temp gauge in mine. IIRC, the breather on mine sits farther towards the back center of the breather cover rather than in the center. You could look it up on Agco parts book and see if the picture helps out any.
Brad
