MM 585 engine
ajl
Is there any value in a non running MM 585 out of a White 2-150. Neighbor pulled this engine and transplanted a Perkins in its place.
Why is it non-running? Assuming the motor is not completely trashed it has value as a parts unit or something that could be made to run to fit a 2-150 or another tractor. Assuming it is the original motor it should have the external oil pump which is highly desirable.
I am not sure why. Either a valve or broken piston. The owner is a HD mechanic and he said what he thought is was. Block appears to be in good shape. Located in the Edmonton Alberta area. Hate to see it scrapped if it is useful.
Someone somewhere could use it, even just the parts. They arent making any more so when they are gone they are gone.
(quoted from post at 06:18:39 05/15/16) Is there any value in a non running MM 585 out of a White 2-150. Neighbor pulled this engine and transplanted a Perkins in its place.
If you are interested in this engine, please email me at [email protected]. I will let my neighbor know that there is interest and then will forward contact info.
