Will A G-1000 Injection Pump Fit A GVI MM
1206SWMO
Will the pump drive-Roosa-master pump-injector lines from a G-1000 MM fit a GVI MM??? As you all know my GVI has the American Bosch PSB pump...Will G-1000 injectors work in a GVI?
I now have my GVI MM running with a new seal in the transfer pump..It has a pop or crackle in it when running so may have a bad injector....Life would be simpler with a Roosa-master pump..
I can buy the drive-inj pump-lines off the G-1000 diesel pictured for $150....I didn't price the 6 injectors...This G-1000 used to sit 13 miles from me....A 97 MF diesel was also at this farm and ended up at the same junkyard 45 miles from me...It still has the pump and lines..
You need to remember that the PSB pump runs engine speed and the Roosa Master runs camshaft speed. I would do a little more trouble shooting before I spent the money. More details tonight.
The offset drive on the Roosa gives you the correct speed ratio. Not sure off the top of my head if the injectors are exactly the same, but they should fit. Probably need to turn the pump down a bit, or you will have more smoke than you need.
I bought the G-1000 pump and injectors and pulled them on Wednesday afternoon...I may need some smoke to beat a 720 JD at a tractor pull in June..
The tractor is currently running with the original American Bosch PSB pump....My brother will look over the Roosa-master if I decide to install it..
