Will the pump drive-Roosa-master pump-injector lines from a G-1000 MM fit a GVI MM??? As you all know my GVI has the American Bosch PSB pump...Will G-1000 injectors work in a GVI?
I now have my GVI MM running with a new seal in the transfer pump..It has a pop or crackle in it when running so may have a bad injector....Life would be simpler with a Roosa-master pump..
I can buy the drive-inj pump-lines off the G-1000 diesel pictured for $150....I didn't price the 6 injectors...This G-1000 used to sit 13 miles from me....A 97 MF diesel was also at this farm and ended up at the same junkyard 45 miles from me...It still has the pump and lines..
