This afternoon I pulled the transfer pump,opened the bleed on the 3rd filter,and pulled the hose at the pump head....I turned on my electric fuel pump and it alone ran the transfer pump and in no time at all I had fuel at both places...I didn't have to use a drill..
I pulled a line at the pump head and cranked it over and had fuel quickly...I put it back on and cranked it over until I had fuel at 2 thru 6 injectors......1 never did seem to get any fuel....I stood on the ground and hit the starter and it quickly started on a 65 degree day..
However we have two problems...
1-After starting it ran away and probably hit 2000 rpms before I got it shut down at the pump....I then started it with the pump half shut off and ran it at 1000 rpms or so for about 10 minutes...It wanted to pop some....I guess the governor isn't working because it wants to run away if you shove the fuel stop all the way open..
2--I have lots of diesel in the engine oil so the pump seal is leaking..It still carried 30 lbs of oil pressure at 1000 rpms....
So it looks like the injection pump is coming off..Thanks to everyone for their help..I couldn't have done it with out you...
