UTU brake parts
dfarmann
It was a rainy day here in nw IL so I opened up the brakes on the new to me UTU. Looks like I need the whole-kit-and-kaboodle, springs, cables, shoes and seals.
Are these parts still available, in kit form or individually? How about the springs for the peddles themselves? Are there any aftermarket suppliers?
Thank You for the help.
Back in the 90s when I did my last U, NAPA got me a maxi kit for some kind of truck that had most of the springs I needed in it.
The parts guy matched up my retainer pin in his illustrated guide, then found me a kit that had those plus the retainers, retainer springs and the shoe return springs in it.
P.S. before you put it back together, figure out which is your strongest return spring for each side. You want those to go on the rear-most or uppermost shoe-I know the anchor pin is off vertical centerline- and to go on the anchor pin last. Otherwise the brakes will come on with a BANG each time. Will still probably clatter in reverse.
