M604 vs M670 gear ratios
Ehren
Do an M604 and M670 have the same ratios in the transmissions and the same ring and pinion ratio?
Thanks!
I believe the 604 will have 9/44 bevel set. The 670 should have 7/38 bevel set.
The gears in the tranny will likely be the same ratios but might be different in some dimensions.
You can go to the Agco web page and get into the parts books and compare. AgcoPartsBooks.com
