My 670 has 16.9x34 tires. Yesterday the casing on one split (old tire). I set out about 450 bales a year with this tractor. As near as I can tell the spin out rims are 16 inch. I am thinking that I would be able to go to 18.4x34 tires move a little faster and slightly better clearance.
Am I correct that the spin out rim is 16 inches? With the bigger tires I would not need water, primary use is setting out bales and a 10 ft pull type brush hog.
Thanks for your thought
