avant 1735
Had to replace the head gasket on my U. pulled the head replaced the gasket and now I am torking the head to specks. The IT service manual says to "tighten the water manifold & intake & exhaust manifold then procede to tork the head, but the diagram showing the tork sequence does not show the water manifold as the first 2 bolts to tighten. In addition there are at leat two bolts on the water manifold that I cannot tork with my tork wrench due to the position of the water line. I guess I am making this too hard. If I tighten the 2 bolts on the water manifold I can only guess because my tork wrench will not fit in the space allowed. So it comes down to this just tighten the 2 bolts on the water manifold then follow the sequence in the manual, Correct? Thanks
